Query widget shows values from symbology grouping instead of the attribute field
875
08-02-2024 09:06 AM
SDev
I have a web map that symbolizes a feature class by grouping values of two fields (AGENCY & STATUS). Both fields are domained.
In Experience Builder, I am setting up a SQL statement in the Query widget.  When I set up the SQL statement to AGENCY is [user input], the provided choices are the grouped values from the symbology groups instead of the values found in the AGENCY field.  I double checked that AGENCY field is correct with just the agency values.
Any idea how to fix this?
TianWen
Could you kindly provide a reproducible sample app? Thanks!
