Query Widget - Filter
782
03-20-2024 04:21 AM
RodWoodford
Hi
How do you filter query search dropdown menus to only display information to the current map extent?
cheers
Rod
DanielFox1
Hi @RodWoodford
When you are in the Query widget go to the Generate from a map option highlighted in my screenshot
Then select the correct map and tick the option for Current Map Extent
If this is the solution you are looking for please mark this as an accepted solution.
