After a recent Esri update I'm having problems updating my webapp in experience builder. I'm using the edit tool but rather than just updating one or two things in the layer and leaving everything else blank its asking for a value in everything. it was working fine before.
I am having the same issue
@NickPotter @LakesGISMaps, Thank you for letting us know. It appears this may be a regression from the ArcGIS Online update last night. Could you please share a reproducible sample with us, or contact Esri Support to submit the issue?
@NickPotter Did you find a way around this? I am also having this issue and am attached to the bug mentioned in the post below (BUG-000185911), but it is still 'In Review' as of this morning.
This issue was logged as a bug Internally. If you have a case with Techincal support, you should have already been attached to the bug. If not, I request opening a case with our team, and we will attach your case to the bug.
