Print Service Issue
4696
16
03-20-2025 05:08 AM
JohnLucotch2
Good Morning,
Has something changed with the Print Widget and custom print services?  As of Enterprise 11.4 and AGOL we are no longer able to use services that worked in Enterprise 11.3,etc.
@TonghuiMing
JohnLucotch2
Amazing!!!  Thank you!!
LakshmiRajeevKumar
Have an issue with the print widget. It is not showing any errors in the console or anywhere else but is not producing any openable output.
Please let me know if this is something that can be corrected or is it a bug in the widget!!
davidson
Hi! Did you find a solution to this error? I'm experiencing the same when trying to use a custom report template.
Thanks!
ToddW_stl
@LakshmiRajeevKumar @davidson -  is your print service set to Synchronous or Async?  I had a print service that runs for ~3mins.  It failed when the service was Synchronous, but for longer running services like mine, Asynchronous fixed my issue.
JohnLucotch2
@davidson - It should be solved at 11.5
HarryPlendl
The solution is to upgrade the Enterprise environment to 11.5 , and until you can do that, there is no fix.
Harry Plendl
Veteran, MS, GISP, Security +
EricLacoursierePQ
Awesome, thank you @JohnLucotch2 !
