Print function not working in experience builder
5477
11
12-20-2024 06:46 AM
GeorgeJonesRIGOV
Hi all, our print function seems to be down today with experience builder. I tried clearing my cache, opening the application in a new browser, etc. None of those actions worked. Is there some hidden workaround i could do?
thanks GJ
GeorgeJonesRIGOV
I got it to work. Just add to take off the old layers and re-add them. It worked when i did that. Thanks for the help everyone!
RickeyFight
@GeorgeJonesRIGOVIs your experience builder on AGOL or enterprise?
GeorgeJonesRIGOV
Enterprise. We recently got an upgrade and was wondering if that was the case.
David_McRitchie
Hey George,
If you recently upgraded and own the print service then I believe this will need to be republished with a specific version of ArcGIS Pro. I would consult the following documentation for deciding which version of ArcGIS Pro you will need. There were a lot of changes in the move to 3.0 so hopefully this fixes it.
David
Esri UK -Technical Support Analyst
RickeyFight
@GeorgeJonesRIGOV
The print service could be turned off or not configured for your new portal. I would assume your upgrade is the issue.
GeorgeJonesRIGOV
Its weird. All my other widgets are working. Its just the print one.
RickeyFight
@GeorgeJonesRIGOVThe print widget uses a print service to work where the others dont. I think that either its not turned on or your org has a custom print service on that widget.
MikeVolz
Have you attempted to create a new print service in your upgraded environment as a test?
GeorgeJonesRIGOV
Yes still the same thing
MikeVolz
Are there any error mssages being thrown in ArcGIS Server Manager for that print service that might provide more information?
Have you reviewed developer tools in web browser when using the print service to also gather information on what is the problem?
