Pop-up text colors missing from Feature Info widget
3501
9
07-31-2023 12:30 PM
RyanBohan
It appears text colors include in a pop-up, are ignored by the Feature Info widget.
Map Viewer:
Pop-up Source:
Experience Builder:
Text colors are not being inherited by the Feature Info widget
Feature Widget documentation:
How do I configure the pop-up to be inherited by the Feature Info Widget?
rVeloz
under the Style option, have you tried changing to Respect the source instead of Custom?
rVeloz
RyanBohan
Thanks @RVelez,
That did it, Thank you.  Why is "Respect the source" not the default?
Wei_Ying
Hi @RyanBohan ,
The "Respect the source" option should be the default. Have you ever changed the setting?
Which version of ExB are you using
Wei
RyanBohan
Hi @Wei_Ying,
I am using Exb builder on AGO, so it should be the most up to date.  Where would I look to verify I have the settings correct?  Thank you
Wei_Ying
Hi @RyanBohan ,
Yes, the AGO version of EXB is the most up to date. This"Respect the source" setting has been the default since 2020 July release.
Wei
TanGnar
I can confirm that during some update to ExB, this caused an issue in my app that I had to resolve by switching it to "Respect the source". It happened on several of my apps, so I know that it wasn't something that I modified. Not sure why or how it got switched, but my apps were at one time 'respecting the source', and then they weren't.
Wei_Ying
@TanGnar Thanks for your feedback! We will take a look if it is a regression issue during release updates.
Marc_Patti
Was this bug ever addressed by chance? I'm experiencing the same issue in AGO Exp Builder where the text colors from the pop-ups are not being conveyed to the Feature Info widget despite having the style setting set as "Respect the Source." I've tried switching between "Respect the Source" and "Custom" to see if that changes anything, but so far the issue persists.
Wei_Ying
This issue should be fixed at the October 2025 Online release and Developer edition 1.19. Thanks.
