Pop-Up is blank when opened from Search widget
1101
11-27-2023 10:52 AM
JustinAnderson
I'm trying to open an attribute pop-up window from the search widget in Experience Builder. When I run the search, I can return a result, and I've set up the map to zoom to the selected feature successfully, but when the pop-up window opens it is completely blank.  Has anyone else experienced similar behavior and overcome it?  Thanks!
JeffreyThompson2
MVP Frequent Contributor
There is this logged bug.
BUG-000162942 for ArcGIS Experience Builder (esri.com)
GIS Developer
City of Arlington, Texas
DavidColey
Hard to tell if this logged bug is related to what is going on here with data layers in a coordinate system other than Web Mercator:
https://community.esri.com/t5/arcgis-experience-builder-questions/exb-map-widget-popup-issue/td-p/13...
Unfortunately, the workaround presented in the bug log isn't really an option for many of us.
TonghuiMing
This issue should be fixed by now. Let us know if you still encounter similar issues. Thanks
