My Location Widget Zoom Level
789
01-16-2025 07:52 AM
NikolaJancic
Hello, I have an app made in Experience Builder where I'd like the user to be able to use the "My Location" widget to track their path and current location. This works fine, but every time the location updates, the map zooms in or out to the scale set in the widget configuration panel, which makes the map very difficult to use while on the move and simultaneously trying to look at other layers.
Is there a way to just to track my location while not affecting the map scale?
AndreasHall
I did some testing and it does not seem to be possible. I would recommend you to use Field Maps instead for this kind of use case. Alternatively, you can submit an Idea that this should be possible in Experience Builder.
