Multiselect with search option
5911
7
04-29-2024 07:39 AM
WalaZargouni
Hello, i need a multiselect with a search functionality just like the one used in the Filter widget in Experience builder, i cannot find what i'm looking for in jimu-ui.
Can someone help ?
2 Solutions
TonghuiMing
@WalaZargouni The AdvancedSelect component is what you are looking for.
TonghuiMing
JeffreyThompson2
MVP Frequent Contributor
I think you are talking about FieldSelector.
https://developers.arcgis.com/experience-builder/storybook/?path=/docs/components-jimu-ui-advanced-d...
Take a look in the advanced folder of the Storybook to see if you find what you want. There are several similar options.
GIS Developer
City of Arlington, Texas
WalaZargouni
It looks like the FieldSelector component yes, but with the FieldSelector it works only with a datasource and its fields. i need to load the items of the select with an api call
TonghuiMing
JanSarata
Hi @TonghuiMing, as far as I know, The AdvancedSelect is still missing the method onSearchInputChanged which is really important while using with API calls as @WalaZargouni mentioned. Are there any plans to implement this method? https://developers.arcgis.com/experience-builder/storybook/?path=/story/components-jimu-ui-index-ad...
TonghuiMing
@JanSarata You are referring to https://community.esri.com/t5/arcgis-experience-builder-questions/experience-builder-advanced-select..., right? We will note that and see if we can implement it.
WalaZargouni
Yes apparently the AdvancedSelect is what i need, the dynamic data example code is not available in the storybook, i tried implementing it as the following
<AdvancedSelect
                  onChange={function noRefCheck(){}}
                  staticValues={[
                      label: 'Label-1',
                      value: 1
                      label: 'Label-2',
                      value: 2
                      label: 'Label-3',
                      value: 3
                  isEmptyOptionHidden
                  isMultiple
                  hideBottomTools
but the problem is that when i select a value nothing happens, you can see it in the attached GIF, is it a bug or am i missing something ?
JeffreyThompson2
The onChange={function noRefCheck(){}} function does not do anything. You will need to write your own onChange function to handle the click event as needed.
GIS Developer
