Menu widget - How to control height?
1207
01-18-2024 09:26 PM
Marokapara
Hi ExBers,
Maybe I've missed something easy here- hopefully!
I'd like to make this menu pop-out fit to text. It's taking up too much real estate and covering up other important stuff. How do I do that?
Workflow - click on the hamburger menu below and then the menu pops out.
Tags (1)
ShengdiZhang
Hi @Marokapara ,
One workaround is to use a widget controller and add the menu widget (vertical type) to it.
Another way is to use an anchored window and add the menu in the window, with a button on the page linking to the anchored window.
Hope it helps,
Shengdi
ShengdiZhang
Hi @Marokapara ,
Hope it helps,
Shengdi
