Map no longer zooms and pans to a point when selected/clicked on the map
440
11-03-2025 04:06 PM
DaveL
Hi there,
I might be completely losing my mind, but did the most recent update change the message actions available on the Map widget?
I could have sworn that there was an ability to have the map zoom into a point feature when it is selected/clicked on by a user. For example, if I had a map of the US with points representing shopping centers, if a user clicked on a point, it would zoom into that feature. However, for the life of me, I can't find this option in the Map widget settings or actions. I'm sure I'm missing it and it's in front of my face, but would appreciate any pointers. Thanks!
Ke_Xu
by Esri Regular Contributor
Hi @DaveL,
This update does not change the map's message action.
Only a Map widget was added. To zoom in after selecting a point, there are two methods:
1) Use the zoom tool in the Popup;
2) Enable "Zoom to selected features," and refresh the app at runtime to zoom in.
Ke
DaveL
Thanks for the quick reply... I must've been mistaken on the previous functionality of the map widget.
That said... it does seem odd that you can set a message action in many other widgets where the record selection changes, it zooms into the feature, but not in the map widget itself.
EMani
by Esri Contributor
Hello @DaveL
The 'Zoom to' action is also available in other widget Action configurations, such as Filter, Table and Search.
- Record selection changes/Map/Zoom to.
DaveL
I know this is an older topic, but I'm still wrestling with this... is there not a way to set the map widget so that if a user clicks/selects a pin on the map, it zooms into that point? It seems like really basic functionality for the UI, so I feel like I have to be missing something here.
