Map - Initial View not being honored
987
02-15-2025 02:57 PM
Hels77
Why would the 'initial view' set on in EB not be honored?
When hitting the apps home button it recenters to the correct initial view, but on refresh, it is off-center, always pushed top left.
It seems to be when an item was selected before hitting refresh. Even though the pop-up (docked as default) was closed before refresh, on refresh it  honors the previous selection and activates the docked pop-up, which then pushes the map to offset against the docked pop-up. This is fine, but the offsetting of the map is annoying for users.
Closing the pop-up does not deselect the item, therefore it is retained during refresh.
And there is no trash can for deselecting the selection after the pop-up is closed? Why is that?
Hels77
Pretty much answered my own question here. The map recenters based on the selection, which is retained on refresh.
Hels77
