Many to many relationship in Experience builder - show track segments in map
11078
22
10-24-2023 02:19 PM
SveinungBertnesRåheim
As far as I have experienced, Experience builder does not read or support established relationships. But! EB makes it possible to establish relationships regardless of defined relationships with Actions.
My issue:
I have a line dataset with track segments. Theese track segments are related to different maintracks. One maintrack consists of many segments. And one segment can be related to many maintracks. This is a classic many-to-many relationship.
It is built in ArcGISpro and then published to one feature service. The feature service consists of
  1.  one line layer (track segments). ID: GlobalID
  2. table1 (main tracks). MaintrackID
  3. table2. Relation-table. Consists of to attributes, GlobalID_Tracksegments and MaintrackID
In Experience builder, I have
  1. added a map with the tracksegments.
  2. Added List widget1 with the main tracks-table
  3. Added List widget2 with the relation-table
I have added theese actions to listwidget1:
  1. Record selection changes ->Framework -Filter data records> Triggerdata Maintracktable, Actiondata Relationtable, Action-connection maintrackID.
  2. Record selection changes ->Framework -Select data records> Triggerdata Maintracktable, Actiondata Relationtable, Action-connection maintrackID.
This put up a one-to many-connection between the maintrack-table and the relation-table.
Then I have added List-widget2 with the relation-table. For this table, I have added joins(Actions) both ways, to the map-features and to the maintracktable.
This widget has a many to one relationship to the line feature service (the tracks). I.e. one track segment can relate to many rows in the relationship-table.
My theory is / what I want to do is:
When I select a row in List1 (Main tracks), I filter and select all common rows in the relationtable. This relation-table has action to filter and select track segments in the line feature service in the map. The result should be filtered and selected track segments in the map.
But!
This does not happen. It will happen if I interact with list2 with the mouse. If I click ONE time in list2, the filter and select in the map is activated. EB does not recognize the filter and selection before I have physically clicked in the list. Although the list is already filtered and selected through the action in list1.
The map consists of test data and is publicly available:
https://experience.arcgis.com/experience/0a8cae796c1d492f87285893b4434432
The map also inclueds the Elevation profile widget. I hoped to activate that one as well, but nothing happens
If anyone wants to try to set up the case, here is the hosted feature service:
https://bodo-kommune.maps.arcgis.com/home/item.html?id=e8523b8722e4456c9ea958f11753a33a
Anyone who know if I am doing something wrong or if the zoom to - function will be possible to use in this scenario?
@EmmaHatcher @ShengdiZhang
Ke_Xu
by Esri Regular Contributor
Hi SveinungBertnesRåheim,
Currently, standalone tables cannot zoom to or pan to features on the map, even though they are related.
We'll think about how this problem can be solved.
Ke
Any news on this topic? @Ke_Xu?  Or do we still need to click extra to zoom to the selected and or filtered features? In my opinion, this is the difference between a successfull functionality or some GIS-tech function that is impossible for most people to use!
This technical article addresses the problem, but I dont think they have a good solution?!
https://support.esri.com/en-us/knowledge-base/problem-zoom-not-available-in-the-action-settings-in-a...
