Make sliding table above on Experince Builder on ArcGIS Online
2285
09-18-2023 12:00 AM
MariusBartašius
So ESRI is moving out of Web AppBuilder and I'm remaking apps on Experience Builder. I'm facing difficulties to make sliding table with all sheets, so viewers can view data, when they want it.
How do I make sliding table above on Experince Builder on ArcGIS Online?
Shen_Zhang
You can use a Sidebar widget to do that. Place the Table widget  in the dock of a Sidebar widget, and from the Sidebar widget settings panel you can set the Dock side to the bottom:
Shen Zhang
Shen_Zhang
Hi @MariusBartašius
Could you please provide more context or clarify what you mean by "sliding table"? Currently in Experience Builder, the previous/next button will appear if there are too many sheets. You can also scroll on the name of the sheets to view other sheets.
Shen Zhang
MariusBartašius
I would like to have table which can be hidden above map. So it does slide to above. So if you look at Jewelery box Exp builder template as the left information is sliding/ can be hidden. I would like to do exactly the same by putting table at the bottom of the page.
Shen_Zhang
Shen Zhang
