Load local json file
1309
11-01-2022 05:19 PM
LefterisKoumis
What's the recommendation to where to place a json file in the ExB file structure and how to access it with the local pathname.
I am using fetch to read the json file but it seems that I cannot to access it if I use a local file.
LefterisKoumis
For anyone who may have the same question, this is what I did
I placed my data folder under the src/runtime and instead of fetch, I used
import data from "./data/info.json";
 If you run into issues accessing your json file, then add this:
 const loadedData = JSON.stringify(data);
    const json = JSON.parse(loadedData);
