I have the following setup:
I can use the Message Actions of the List widget to filter the points on my map, but only when the user selects a record in the list. Before the user selected a record in the list the map draws all points, and there's 300,000 of them. Instead I would like to either:
Are either of these possible? I've tried recreating #2 above with a Query widget but that only queries my related table and thus doesn't show the related points on the map.
There is an option in the Filter widget to apply a filter automatically, so it will be turned on on-load.
This trick with the Filter widget is probably the best option for your issue with the OOTB widgets.
Thanks for the suggestion @JeffreyThompson2 . However as described in my original post the Query widget only queries the related table records. Although I can configure Message Actions to filter the related map points it still requires the user to select the queried record in the query widget results panel to do that...so basically it's the same issue as I originally outlined:
To clarify, the tips in my prior post were referring to options in the Filter widget, not the Query widget or the filter within the List widget.
Here is a configuration where the first object in the List is automatically the only one shown on-load.
Maybe I'm not fully understanding your question. Have you looked into Data Views? There might be a solution with them. https://doc.arcgis.com/en/experience-builder/latest/build-apps/select-data.htm#ESRI_SECTION2_E34F786...
