Limit BaseMap options in Experience Builder
2746
05-11-2021 12:43 PM
BennyNein
I'm experimenting with the map widget in Experience Builder and I was wondering if it's possible to edit the amount of base maps the end user has when the base map option is turned on?
I'm not entirely sure if this would directly be possible through Experience Builder or the Web Map which the Experience Builder is pulling from.
Basically, I only want the end user to be able to select from four different ESRI base maps instead of the whole range that is offered. Would it be possible editing the JSON?
Any help would be greatly appreciated. Thank you!
TonghuiMing
Hi @BennyNein - it appears to me that your concerns are similar to what was mentioned in this post - https://community.esri.com/t5/arcgis-experience-builder/non-compatible-basemaps-showing-in-basemap-g.... We will take a look at them together.
David_Brooks
MVP Regular Contributor
@TonghuiMing @DavidMartinez is a dedicated basemap widget on the roadmap for 2022?
David
..Maps with no limits..
TonghuiMing
An OOTB Basemap Gallery widget has been provided in the recent AGOL 2023 Jun release.
Julia_vanRavenswaaij
Unfortunately the Basemap Widget and the Basemap toggle under map tools do not seem to correspond. You can edit the basemps with the widget, but not the basemaps used in the gallery that you turn on with the toggle. There should be a settings option there as well.
