Shapes sent to survey123 widget when editing survey record
316
04-22-2026 04:33 AM
HanliePetoors
I'm working in ArcGIS Enterprise 11.3.
In a page in a web experience I have a web map and a survey widget for creating a record. I send the shape of a selected polygon in a specific layer in the map (say layer A), along with one of its attributes to the survey widget. The survey widget writes to layer B.
On a second page I want to edit the existing records, so I have the same map and a different survey widget for editing an existing record. When I click a survey record from layer B on the map, its information is sent to the survey widget.
I would like to be able to select another polygon from layer A in the map and send that to the survey record being edited in the second page. For example, if a user selected an incorrect polygon from layer A when they created the survey record, I want them to be able to select the correct polygon from layer A and replace the current polygon in the survey record.
Is this possible? I can't see an obvious way to do that but perhaps someone can think of a workaround?
Hanlie
Tags (1)
