Layer Widget and Map Filter
845
06-17-2025 06:41 PM
JeetzPatel
Hi all, does anyone have any ideas on how to replicate something like this? The layers widget appears to have a map clip function that allows users to partly clip out the layers on the map.
https://maps.boprc.govt.nz/apps/BOPRC::inherent-biophyiscal-risks/explore
(view in My Videos)
I'm guessing it was a clipping layer on the web map, and the Inherent Biophysical Risks layer being a raster that gets filtered? But if anyone  has any other ideas that'd be much appreciated 🙂
Tags (1)
Marshal
There is probably multiple ways to achieve this, and I am making some assumptions, but here is what they appear to be doing.
1)  Rasters on top of the basemap, but under a transparent dark rectangle to dull colors.  Vector boundary layer for all Management Units on top of the transparent rectangle.  They also appear to have features for each "outside" area for each Management Unit.  These vector layers have the same dark transparency applied to fill, and the larger rectangle has holes cut into it matching these boundaries.
3)  When user turns on a Management Unit, it is doing so in a List widget that uses message actions to make a selection on the chosen Management Unit and also filters the dark transparent overlay areas to create a hole over the chosen unit making the colors more vivid.
As far as the widget configuration, it looks like they have a List widget (with png images for each Management Unit) grouped with a Layer list widget (toggle for Containment) inside the main Widget Controller set to expand all on opening.
TonghuiMing
@JeetzPatel The original app uses a List widget (grid layout arrangement), which is then configured with framework-level message actions: Map widget > Zoom to & Filter.
