Keyboard Controls for Experience Builder's Built-In Image Carousel
5729
10
07-25-2024 08:48 AM
JeffreySchmidt3000
I am wondering if there are keyboard controls for the image carousel in Experience Builder that gets used when there are multiple image attachments connected to a record?  It would be a worthwhile component to include in a future release to meet some ADA requirements if it is not already incorporated.
Thank you
2 Solutions
TonghuiMing
Hi, @JeffreySchmidt3000 - thanks for the clarification. That does look like a missed case; we will look at it and try to resolve it.
Also, just out of curiosity - is your image configured with links or not? I know it may not affect your above behavior, but this could be something I want to include in the testing later.
Thanks for bringing this up!
TonghuiMing
@JeffreySchmidt3000 The keyboard access issue for the image gallery has been fixed in the recent AGOL release update.
TonghuiMing
Hi @JeffreySchmidt3000 - to be specific, is it the feature pop-up attachment, or feature info widget, or inside the image widget that you are talking about?
JeffreySchmidt3000
Hi @TonghuiMing Let me send along some screenshots.  It is part of the image widget.  I cannot get focus on the image buttons on the left/right of the image container, it simply skips past them both.   Here is an example public experience.  https://experience.arcgis.com/experience/0810844003f149faa1a3aeaa64d7d42e
TonghuiMing
JeffreySchmidt3000
Thank you @TonghuiMing!  I appreciate you looking into it more.  To answer your question, no the image was not configured with links.  I have considered using a link so that the image may be opened to a larger size in a window. Often the viewers of my experience are looking at a list, where they see a small thumbnail sized image gallery.  To view a larger image, I could include a link that opens an image in a window.  A better solution may be including optional expand/resize controls in the image carousel frame.
TonghuiMing
I see. We will take that into consideration as well.
Billy
Hi Jeffrey,
The experience in the link (https://experience.arcgis.com/experience/0810844003f149faa1a3aeaa64d7d42e) of you answer has a filter section with a widget behavior that I don't how it was created.
Do you have any info regarding how that filter functionality was created, type of widget and configuration?
Regards.
JeffreySchmidt3000
Thank you for reaching out.  It is the stock AGOL filter widget and to make use of the check box/multi select, I have them set up like the screen shots below.  I used "contains predefined multiple values" in one filter and "is any of" in another to give options to the user.
TonghuiMing
JeffreySchmidt3000
Thank you, this is very helpful! 👏
