Keep Local Time Zone in CSV Exports?
2599
01-31-2024 10:37 AM
jchester73
Inspection tables in Experience Builder are showing the correct local EST timestamps for an inspection date. When exported to CSV, the time is in UTC which is offset by several hours. Is there a setting or workaround, without manual recalculation to a new field, that will keep timestamps in EST when exported?
Tags (5)
SerjStol
I also encountered this issue. We have data in DD/MM/YYYY in AGOL, everything looks fine but in the export via the table widget it changes it to MM/DD/YYYY. Have changed it in the web map settings, makes no difference.
jchester73
I see that my timestamps export perfectly from my older WebApp Builder apps and the format in general exports better from WAB. For whatever reason ExB exports incorrectly and defaults to the database instead of what is appearing in the table view..
LakshmiKanthanM
Did anyone else figure this issue out? We have recently observed this error. When we try and export data from an Experience Builder App (with time zone Pacific -UTC - 07:00), we get the data exported with timestamp values in UTC. Is there a bug reported for this in Experience Builder?
LakshmiKanthanM
We were able to create a bug: BUG-000173325 after working with the ESRI Technical Support team. Anyone who is experiencing this issue, please track the bug to see the status.
