June 2026 Update - List widget: Data Action no longer selects table data
387
06-30-2026 02:01 AM
NeilWebber
Hi ESRI
I have a number of ExB apps that use list widgets to select a feature which activates a series of Feature Info widgets that are set to show 'selected data'. Some of the Info widgets are based on the same feature layer that populates the List widget, some are based on table data that has a common UID field.
All of this was working perfectly until Friday. Now, when a feature is selected in the List, the Info widgets that are based on tables fail to load - they just show the pulsing pause animation. The behaviour is consistent across a number of separate ExB items.
I can solve the problem by removing the data source of the List from the Experience and re-adding, and then re-connecting all the other widgets, but it's not acceptable to have to do this across a whole load of apps because an update broke a common workflow.
Console shows errors that I don't have the knowledge to understand, but maybe this line is pertinent -
https://js.arcgis.com/5.1/esri/core/workers/init.js"
lineno:3
message:"Uncaught TypeError: Cannot read properties of undefined (reading 'spatialReference')"
 - trying to read a spatial reference from a non-spatial table?
Thanks for any help, Neil
StephanieW
Hi @NeilWebber I suggest working through this on a Support case. I am unable to reproduce since I don't have any older apps with the specific configuration but an Analyst can take a closer look with you at any that are still reproducing the problem. https://support.esri.com/en-us/overview
Wei_Wang
@NeilWebber  thanks for your feedback. I wasn’t able to reproduce the issue on my end. Could you please contact Esri Support to share us more details about your app and case? Appreciated.
