June 2026 Update - Calculated expressions not working correctly in edit widget
343
3 weeks ago
WillyG
Hi. I've just noticed that calculated expressions and info widgets are not working as expected in the edit widget of experience builder since the June 2026 update.  It is working correctly in map viewer. I'm passing a id based off user selection and also displaying info elements based off that selection. In experience builder it does not update based off my selection. See attached screenshots of how the behavior differs.
Kind regards
Willy
KimOllivier
Honored Contributor
It appears that there are many bugs introduced in the June 2026 update. I have just found my dashboard is broken with a missing link that cannot be fixed.
DougBrowning
WillyG
I think this related to the changes to conditional visibility.  I we click outside of the field it is fine, which is the fix that ESRI implemented.
