June 2024 update broke query widget results
3405
7
06-27-2024 08:14 AM
NicoleJohnson
MVP
I'm using ArcGIS Online.
I've created an Experience Builder site that has (among other things) a map and a query widget. The map contains a layer with pop-ups created from multiple Arcade attribute expressions housed in a text content block. The query widget is supposed to return the same content as the pop-ups, but after the June 2024 update, it no longer does that (despite the "use web map settings" box still being checked). Instead, the query results show the default field list content you get when you haven't configured pop-ups at all for a layer.
I've attached an image below where you can see the pop-up next to the query results. I've had to blur stuff out, but you can see they're clearly different.
I use Arcade attribute expressions because I have related data I need to show the user, and I don't like the built-in related records options in Map Viewer for this particular use. Using an Arcade content block is also out of the question because the query widget can't show those.
Anyone else experiencing this? I'm going to report it as a bug since there doesn't seem to be anything I can do on the Experience Builder/widget side of things.
Feeling SO disappointed right now. I was all excited looking through the updates and then had the thought, "I sure hope all my stuff still works," and what do you know, it doesn't.
Tags (1)
Jianxia
@NicoleJohnson, thanks for submitting a ticket to Esri Support and posting the issue here. We will follow up and keep you updated.
WorcesterGTSS
We are experiencing the same issue. We have the Query widget configured to "use web map settings" but the results returned show the full list of attributes you see when a popup is not configured.
WorcesterGTSS
The widget is now working correctly in our app.
TianWen
We have successfully reproduced the issue and are currently working on a fix. Thanks for the post!
NicoleJohnson
MVP
This is fixed! Thank you, @Jianxia and @TianWen.
PAGIS
Hi.
Any chance that the February 2025 update broke the query widget in ExB like what happened in this thread?
I have users saying that the tool worked earlier this week but now the tool is yielding no results. specifically the drawn graphic intersect portion of the query tool. i am able to draw a polygon but when applying the spatial filter, the window yields no results. says 0 records were intersected. i have tried to rebuild the tool twice from scratch and the same thing is happening.
@Jianxia @TianWen
TianWen
We haven't been able to reproduce the issue. Could you kindly provide reproducible data or more details to help us investigate further?
