Issues with Query and Print Widgets after June 2024 Update
2308
07-23-2024 10:36 AM
Jan_TPS
Hello, we are currently noticing some bugs in the Query and Print widgets after the June 2024 update.
App link for reference: TPS Crime App YTD
Issue 1: Query results not showing on map
1) Using the app link > Query tab > select a Crime Category (eg Auto Theft) > click Apply
2) On the map, click the Layers icon > hide All Crimes YTD layer > no results displaying (in previous releases the result of the query would normally show up)
Issue 2: Persistent color highlight when printing
2) Go to Print tab > click Print > in the results tab, the map that has been generated has highlighted points (highlighted in yellow), this highlight was not present in previous releases > attached is a sample map
Could you please advise if a patch fix can be applied? We have several users who have notified us of these issues. Thank you!
@Jianxia
Ke_Xu
by Esri Regular Contributor
@Jan_TPS  Hi, this issue has been fixed.
Ke
Jianxia
@Jan_TPS , it seems data is no longer available to the app.
Jianxia
Jan_TPS
@Jianxia, could you please try again? There should be data now. It might have been going through a scheduled data update earlier. Thank you.
Ke_Xu
Ke
Jan_TPS
Thank you @Ke_Xu!
