Issue using date as filter
1945
03-30-2020 06:39 AM
SeanMcGee1
Hello,
In the SQL Expression Builder, when selecting date as an input and "Ask for values" enabled.
Then when a user tries to filter, it will input the incorrect month (+1). For example, in this .gif below, I select March 30th (should be 03/30/2020). But the text input is 04/30/2020 in the input box. It will also skip to the next month in the calendar UI.
Just thought I'd report this issue!
Thanks
TonghuiMing
This issue was fixed after the March release for AGOL 8.2 (2020 July).
DavidMartinez
Hi Sean,
Thanks for reporting this. Will take a look at it and get it fixed. Hope all is well.
FYI Tonghui Ming
Cheers,
David
by Anonymous User
Not applicable
Hi All,
I am also having this issue, so we can't deploy our app until this is fixed. Has there been any update since March? Thanks!
TonghuiMing
