Is there a Time Slider Widget for Experience Builder?
25951
44
10-15-2020 11:03 PM
MarkChilcott
Hi Peoples,
Is there a Time Slider Widget for the new Experience Builder in AGOL?
I have an app developed with WebAppBuilder that I want to convert over to Experience Builder.
Is there a Developer sample - could look at development.
Cheers,
Mark
sofoo
Thank you!!!
MM23
Is it possible to use the timeline widget with a WFS? if so, how?
SolanaFoo2
@TonghuiMing  When I go to select the data source, I see the pane open up but the page completely freezes and I cannot interact with it anymore.  Any ideas?  I've got ArcGIS Server services registered in AGOL, feature classes and layers in Web Map are time enabled.err.PNG
SolanaFoo2
TonghuiMing
@SolanaFoo2 Based on your screenshots, it seems like the entire app or browser got jammed. It may not relate directly to the Timeline widget but rather more of a performance issue. Is it possible to share the app with me via DM to take a look at?
TonghuiMing
@SolanaFoo2 - The timeline widget frozen problem should be fixed in the latest AGOL 10.3 release. Thanks for the feedback.
sofoo
@TonghuiMing Thank you for the follow up!  Sorry I didn't contact you, I didn't see a place for DMs and we ended up using a work-around (choosing individual layers).  This is great though, thanks!
TonghuiMing
Yes, choosing layers did work before. Glad to hear that.
Ashok
Can we bring and use this Timeline widget in ExB with ArcGIS Enterprise 10.6 (not in AGOL)
If we can't use this one, then do you have any plan in releasing this widget in ExB for ArcGIS Enterprise in feature releases.
Ashok
TonghuiMing
No, Timeline (AGOL v10.2) will not be compatible with older Enterprise versions. The recent Enterprise 11.0 is equivalent to 10.1, so this function will not be included until the next Enterprise update.
Feel free to bookmark and refer to the version information since it will be updated each release - https://developers.arcgis.com/experience-builder/guide/release-versions/
