Hi, is there a way to turn of this layer warning notification, which is shown when opening an experience builder app?
Using ArcGIS Enterprise 11.3 I have made an experience builder app, where not all users have access to all map image layers. The different access is managed through groups. If a user is not a member of perticular group the user can't see the layer. This works great. But the user will see this warning saying "Sorry, you don’t have access to the resources...".
The user does not need to know there are layers not visible for them. So I want to turn this notification/warning off. Is this possible, or is there another way I can hide layers for specific users?
Hi @MathiasKPoulsen , this is as design so far, when some resource is not loaded, we show a notification. And this banner is also to prevent you see repeated logins when you try to use the app if some data are not permit.
You can click ignore on the banner to avoid it until you refresh your app.
I think we can log an enhancement in future to let you decide whether to show this notification.
Hi @Wei_Ying , thank you. Sounds great if the notification in the future can be optionally.
Is it not possible to disable it by edit some json file on the server today?
I think this is for WAB developer edition, but may the same can be done for the default WAB on Enterprise?
This feature would make it a lot easier in big projects where some users need to see certain layers and other don't.
We are working on to provide an option to disable the login/accessing warning, it should come soon next release.
Wei
Hi @Wei_Ying ,
Did the June 2025 update resolve this issue. If yes, where can we find it?
Thanks!
Hi @Wei_Ying ! Do you know if this has been added to AGOL yet?
Yes, it is available on AGOL on June release.
Can you help me figure out how to configure the app so the warning doesnt show?
In Experience Builder of AGOL, please go to General setting of experience, and then click "privacy & security".
Under the security section, use the two new options "Skip sign-in prompt for secured resources" and "Skip credential banner". 2025-07-12_13-43-30.jpg
