Invalid redirect_uri Error: 400
6275
12
08-31-2023 11:58 AM
JacobWallace
We are beginning the process of transitioning away from Web AppBuilder to Experience Builder.  I'm starting with a basic template "Billboard".  I'm simply wanting to add the Web Map that supports our Web App.  This particular web map also contains content from our Partner agency and mostly password protected.  When I go to "Add Data" and select the map, I get the following error in an ArcGIS Portal Directory window (see screenshot).  Any thoughts on what I should do?  Can I enter this Partner organization's URL somewhere so that the Experience Builder application will allow this map?  Thanks!
Jacob
Wei_Ying
Sure. You don't have to change the layer sharing scope, we just need to access the map to repro this "invalid_redirect_uri" error.
CraigMadill
Hi Jacob,
Just curious if you found a resolution to this. I get the same invalid redirect_uri error when adding certain web maps to Experience Builder. Since our web maps have a variety of data sources it seems as if Experience Builder gets caught up trying to authenticate them.
Thanks, Craig
baohuachu7
Check the application in portal: Settings->Registered Info->update->Redirect URI is as: https://your-portal-domain:3001/
