installing Experience Builder SDK npm start error 4091
910
06-27-2025 07:32 AM
LoriEmersonKDOT
So, I installed Experience Builder SDK successfully on our production portal, but then tried to move it to our test portal.
I've been able to change the "https://localhost:3001/" to use the Client ID from the Experience Builder credentials on the test portal. (Note: I have already deleted the Experience Builder Credentials from the production portal.)
However, when I try npm start from the windows command prompt, I get the EADDRINUSE error, errno -4091 on port 3000.
I tried:
netstat -ano -p tcp |find "3000"
taskkill /F /PID <PID>
where <PID> is the far-right number from the netstat command, as described in this post: https://community.esri.com/t5/arcgis-experience-builder-questions/arcgis-experience-builder-uninstal...
However, I still get the same error.  Any advice on how to uninstall and reinstall Experience Builder SDK?
JunshanLiu
Are you running two Experience Builder servers? You don't need to uninstall the ExB, you can just stop one and start another one.
LoriEmersonKDOT
I just have the Experience Builder installed one place on my C: drive, with the server folder and client folder.  How could I run two servers?  Do I not need to run the "npm start" command from the server folder?
