In-line Authentication instead of Popup
1012
05-28-2024 08:29 AM
NickKoopman
I'm trying to deploy an ExB (1.12) app that requires access to secured services. The intent is to use this app on iPads.
When asked for credentials, the prompt comes up in a new window. Our corporate policy for mobile devices is to disable pop-ups by default. Because the login prompt comes from a pop-up, I can't authenticate unless I go into the iPad's settings and explicitly enable pop-ups. I can't have that workaround when I push it to our users.
Is there a setting in the config.json file where I can switch the login to in-line instead?
Thanks in advance
Nick
