Experience Builder Edit widget don't update for all points of the same source (layer)
1043
05-26-2024 01:35 PM
AdedoyinAjeyomi
I created an experience builder with three layer data, I added the experience builder edit widget and configure all the three layer. Everything seems fine but when I click on some point and make my edit ,the update button don't work for some while it worked on some point ,I used blank experience builder and I didn't create view or configure any logic. What could be wrong ??, I transfer the same app to webmap and everything works fine. So I belive the experience builder is the problem
Tags (3)
Laura
by MVP Regular Contributor
Can you edit the same points that are causing issues in EXB in map viewer (new or classic)?
