How to uninstall ArcGIS Experience Builder (Dev Edition)
2138
04-27-2021 09:42 PM
B_Coubrough
Can the ArcGIS Experience Builder (Dev Edition) be uninstalled without uninstalling Node.js?
I tried using the npm uninstall command but that didn't work.
jcarlson
Just delete the ArcGISExperienceBuilder folder!
When you set up to use EB, you used npm-ci to add the necessary packages to the EB directory. But Node itself is installed in a totally separate directory, and will not be affected by this.
If you really want to get into the weeds, read through the npm docs to see what npm-ci is actually doing, and then look at the contents of the package-lock.json file.
- Josh Carlson
Kendall County GIS
DanPatterson
MVP Esteemed Contributor
No clue... but from this document, the worst case scenario would be reinstalling Node.js from the link in this thread
Get Started with ArcGIS Experience Builder Develop... - Esri Community
... sort of retired...
jcarlson
- Josh Carlson
Kendall County GIS
