How to remove comma separator in Experience Builder table
20943
39
07-13-2022 03:31 PM
CalebAnderson
Hello! I'd like to remove the thousands comma separator in the table I have in an experience:
I tried going to the visualization for the feature and unchecking the thousands separator. Also tried pulling the data from a web map where I did the same with no luck:
jfischer91
I'm also very interested in this functionality! If you have an ArcGIS Idea post for it, please link so I can upvote.
CaseyRandolph
I am interested in this feature, as well. We recently rolled out an experience that includes a table with a document number. The comma is getting passed through to Survey123 and we are having to remove it through Python when the survey is processed.
KKelechenyi
Honestly, I'm stunned that this is still not solved.  Hoping Esri enables this widget to use custom settings sooner than later.
Krocha
It is still under review since May 25, 2022. It is frustrating having to use numbers in a string field.
AprilJohnson2
Still waiting for a solution on this ESRI!
Daniela
We are also struggling with this problem! Shouldn't be so hard to implement, no?
ChristopherRobinsonEdu
Agreed.  Would be wonderful for ID's to not have commas.  I understand you have to prioritize enhancements and all but usually you knock out the low hanging fruit as well.  This seems like really low hanging fruit, almost like picking it up off the ground.
JordonHenderson
Still showing thousand separators. Any resolve to this issue? It should be fairly straightforward.
Gerald_Farrell
Change the field to text in webmap
eleanor_ME
Having a similar issue - at the moment the thousands separator settings in the web map are being honoured in the Experience Builder tables, but the significant digits settings are not. When will there be a fix for this?
