How to remove comma separator in Experience Builder table
21061
39
07-13-2022 03:31 PM
CalebAnderson
Hello! I'd like to remove the thousands comma separator in the table I have in an experience:
I tried going to the visualization for the feature and unchecking the thousands separator. Also tried pulling the data from a web map where I did the same with no luck:
jcarlson
What version of EB are you using? And is your datasource being referenced by the table directly, or is it a view? In older versions of EB, data source views would ignore field-level formatting options of the original data source.
- Josh Carlson
Kendall County GIS
TianWen
This is actually what we are implementing recently and the table will be able to honor the thousand separator (and other settings) soon.
CalebAnderson
Thanks @TianWen, looking forward to it
ShefaliVerma_afsc
I still can't format the fields in the Table widget.
RobertAnderson3
MVP Regular Contributor
Any updates on this @TianWen ?
JoshTownsend
@TianWen can you provide an update on this enhancement? Thousand seperators are still showing in enterprise Experience Builder 10.9.1 atleast.
d-slet
I'm utilizing Enterprise Builder in AGOL and we still are experiencing this issue. I tell you this because Enterprise releases generally follow AGOL and it has yet to have been implemented in AGOL. Maybe and ESRI rep can chime in but I have not found a resolution to this issue.
Take care.
AW_Grove
I'm still seeing this issue too.
CristianGraf
Have something similar...  with a bonus problem!
When exporting a CSV on the export tool, we have some issues on the CSV. As some people are entering commas (,), well colums and lines are a total mess on Excel.
Any ideas how to change the separator on ExBuilder? On the REST?
Thank you! for any help or work around!!!
