How to open a Card based on selecting on Map (by clicking a feature)
1370
10-04-2023 08:39 AM
sgambrel_Bouldercounty
Hello,  I'm pretty new to all of this, but have successfully built out an experience and just need a smidge more functionality.  Want to create a trigger that when someone clicks a feature on the Map, the corresponding Card opens.  Card is in a Window, rather than on the Page, if that matters.
I've created an Action with the trigger "Record Selection Changes" to the Framework, using the map's single data layer as the Trigger Data and that same layer as the Action Data (to ideally trigger the card opening).  That's not working and I cannot figure out another way given the limited options I'm presented.  Any thoughts?  Is this perhaps not even possible?
Here's the link:  Bike Event & Resources Map (arcgis.com)
Thank you!
Katie_Macintyre_Atmos
Hi there? Did you find a solution to this one? I'm after the same functionality but can't seem to find a way round it
