How to create linked dropdowns (groups → layers) in Experience Builder 1.14?
1213
03-21-2025 06:43 AM
MohaRIZKI
Hello,
I have two groups, and each group contains several layers. I would like to create two dropdown lists:
The first one allows the selection of a group.
The second one updates automatically to show the layers available within the selected group.
A "OK" button will then display this information on the map.
I’ve seen that it is possible to create dropdown menus based only on the layer's attributes. Do you have a solution to manage this at the group level?
Thank you for your help!
DanCopKac
anywhere you have a widget with 'SQL Expression Builder' you can make a query that shows filtered lists:
MohaRIZKI
Yes, that possibility exists, but the dropdown only filters based on the attributes of the layer. What I'm looking for is a way to have a list of layers where, when a user selects a layer, it appears on the map. Do you know if that's possible?
Ke_Xu
by Esri Regular Contributor
Hi @MohaRIZKI,
Please follow this enhancement.
ENH-000167838 The choice to configure a group filter with values filtered by previous or all other expressions in ArcGIS Experience Builder.
Ke
