How to add images with transparent backgrounds on buttons?
3061
8
09-23-2021 06:36 PM
Hayley
I'm using an image with a transparent background, however uploaded into Experience Builder it turns into a white backgroud. Is there a way to work around this so it doesn't appear on the hover colour of my button?
HL
jcarlson
MVP Esteemed Contributor
No, a PNG should be able to do it. But you say they're screenshots? That will capture whatever is displaying on your screen, and a screenshot can't really pick up transparency. That would have to be done in an image editor.
I'd second @CourtneyMenikheim's request, could you upload the files you're using? You can attach them to a reply here.
- Josh Carlson
Kendall County GIS
jcarlson
It shouldn't be doing that. Can you confirm the file format of your icon? Certain formats do not support transparency.
- Josh Carlson
Kendall County GIS
Hayley
They are PNG screenshots, do they need to be jpg?
HL
jcarlson
- Josh Carlson
Kendall County GIS
Hayley
Hi, I have tried again with downloading transparent imagery, but still getting the same issue. I have uploaded the file I'm using
HL
jcarlson
Can you elaborate how exactly you are downloading these?
Also, you might consider downloading something like Inkscape and simply making your own icons, or using it to alter existing SVG files (provided they have the right license), and export to PNG.
- Josh Carlson
Kendall County GIS
CourtneyMenikheim
Can you provide a link to the files, or add them in a comment?
Courtney Menikheim | Application Developer | @thecmenikheim
Hayley
Hi, I have attached the image I am using
HL
TonghuiMing
@Hayley - Unfortunately I don't believe the image "pop test.png" has a transparent background - in fact, it seems to have the gridded canvas with it.
If you are using the images as background inside the button widget, then setting the Fill color for the background as transparent will do the trick. See the comparison when you change the fill from the default to transparent:
Another interesting thing is, I do wonder how you achieve the original setting to put an image inside a button as background but aligned to the bottom, or you used an Image widget to lay on top of the button widget?
Hope it helps,
