How can you change popup design & appearance?
5684
10
07-14-2022 11:11 AM
ShadSan
Hello, Is it possible to change the size and location of a popup window in web version of Experience Builder?
BethAnnWinebarger
Might depend on the pop-up template you choose, but for the 'Confirm' template you can align in to an edge or centered and change the size by pixel # or by dragging an edge (an the double line). Check out the right side of the screen under 'Position & Size' for alignment and pixel size.
Beth Ann
ShadSan
Thanks. I need to adjust the layer info pop-up.
TonghuiMing
If you are referring to the feature popup window on the map, it cannot be customized at this time, unfortunately. The style and all are inherited from Map Viewer/API:
ShadSan
Thanks.
JonathanAttard
Hi, is this still the case, or can you now edit how the popup looks? If not, can you do some other workarounds for this?
RandyMcGregor_BMcD
Is there any way to get it to populate in a sidebar the way the 'minimalist' instant app allows?
LJackson29
I agree that this is needed. I have my pop-ups configured to pull into the Feature Info widget, but in the map, I would really like to adjust the formatting as it is rather awkward the way it is now, or alternative the option to have a second pop-up that is simpler.
JonathanAttard
I found out that you can modify the popups for each layer from within the ArcGIS Web Map by using Arcade code. This allows for a lot of customisation when using the flexibility of HTML.
https://developers.arcgis.com/arcade/
PaulHallett1305
Hi Jonathan
Can you load an example?  Can't seem to find any sample code on the net to get going
Cheers
Paul
