Help! Error: "Cannot read properties of undefined (reading '0')"
1767
9
11-11-2025 03:31 PM
LayerItOn
One of my pages in exp.b. is throwing up this error when I go to check the pending items. No other pages are have this problem. If I duplicate the page (Viveros), the error persists (Viveros 2). Anyone experience this before?
NicoleJohnson
MVP
@LayerItOn, I've had this happen from time to time, but especially during the week or so after the October ArcGIS Online update. If you open your app in a new tab (you will lose your unsaved work), does the message go away?
LayerItOn
No luck, message still shows up for that page. Hmmm, I didn't think that it might be related to the recent update
NicoleJohnson
MVP
@LayerItOn, do you remember what you had done just before seeing the message? Most frequently this has happened to me right after setting a custom color somewhere on the style pane of a widget (but I've seen it after doing all sorts of things). I think maybe the JSON sometimes gets messed up, so if you can functionally reset it by going back to whatever widget you last interacted with and changing something about it (or deleting and reconfiguring it), maybe that will work?
LayerItOn
I deleted a hidden page, but that page was not linked to anything else in this page
Laura
by MVP Regular Contributor
Try to duplicate your whole EXB and start from a new one (essentially copy it and see if the error goes away)
LayerItOn
Error persists with copy 😞
Laura
hm when I've had the error support made me re-create it but to do for a whole page vs a widget is more of a hassle. I know it's simple but did you clear cache/history and try again?
LayerItOn
Darn, that is a good idea, but no luck.  I tried to clear the cache/history, but still have the error.
ShengdiZhang
Hi @LayerItOn ,
Could you share a sample app with me so we can take a close look at it?
Shengdi
