Glitch in Experience Builder's Query Function
1538
06-21-2023 11:00 AM
ML123
Hello Community,
I'm currently facing an issue, and I need your assistance. I have developed a web portal map using the experience builder.
Within the portal map, I have created five different maps by utilizing the views navigation tool, all based on a single web map. In order to display different content on each map, I have used queries to extract the specific features I want to show for each view.
However, I've encountered a problem. While the queried features display correctly in the edit view and live view, they don't seem to work when I preview the map. Instead, all five different maps in the Views navigation show the same output, disregarding the queries I had set up.
I'm wondering if this is a recent glitch in the experience builder. When I initially built this map a few weeks ago, I didn't experience this issue. However, upon checking the map yesterday, I noticed that the queries weren't functioning properly.
Has anyone else encountered a similar problem or have any insights into what might be causing this issue? Any assistance or suggestions would be greatly appreciated.
Thank you in advance for your help!
CherieBryant
I'm not sure if it's the same problem, but I was having difficulties with the query widget display as well. Here's my question about it. I haven't figured out a solution so far.
unexpected query widget results
Jianxia
@ML123 Could you please provide a reproducible sample while contacting Esri Support to help us investigate the issue?
TonghuiMing
@ML123 To help collaborate - are you using the ds filter function for each map view? Or some filtering elsewhere that you mentioned as "queried features"?
TonghuiMing
@ML123 Tested the sample provided through the support ticket, still not able to reproduce the issue. The previewed app also has filters correctly applied:
