Issue with the installation of the client (Developer edition)
2849
9
10-25-2023 07:46 AM
JasonBOCQUET
Hello community,
This morning I try to install the developer solution.
It works with the server, i can already create new experience on the developer environment but, with the client, it doesn't work.
When I try to C:\ArcGISExperienceBuilder\client>npm ci in the cmd.exe i have a LONG error message that I can't solve, here is an example (not the entire message)
Anyone have an idea of what to do ?
JeffreyThompson2
MVP Frequent Contributor
Took a little digging on the node website, but here is a download for Node 18. https://nodejs.org/download/release/v18.18.2/ I don't think being on 20 should be a problem.
Are you running your console in Admin mode? Using Admin mode tends to work better and could clear the error.
GIS Developer
City of Arlington, Texas
JeffreyThompson2
Possibly you just made a typo in your question, but the command you are looking for is npm ci.
GIS Developer
JasonBOCQUET
mistake when i write my question. I correctly write "npm ci" in my cmd.
I edit the OP.
JeffreyThompson2
The error suggests a problem with one of the node packages used in Experience Builder. node-sass seems to be the package triggering the error and it is listed as depreciated.
https://www.npmjs.com/package/node-sass
Try:
npm i node-sass
npm i
But, even if it works. Please contact ESRI support. This could wind up being a major issue for any new users.
GIS Developer
JasonBOCQUET
I have to do this command in C:\ArcGISExperienceBuilder\client right ?
After i use "npm i node-sass" i have the same issue. (it's too long in one screenshot 😞 )
JeffreyThompson2
If you are getting the same error, it is almost certainly a problem with the node package. Please contact ESRI support. They may need to release a patch for Developer Edition.
GIS Developer
JeffreyThompson2
https://community.esri.com/t5/arcgis-experience-builder-questions/fails-to-install-arcgis-experience...
Are you running node 18? Someone just posted a similar issue and found a resolution.
GIS Developer
JasonBOCQUET
I'm using node 20.9
I don't find the v. 18 on the node.js website so I can't test if it's possible with v18 !
JeffreyThompson2
GIS Developer
JasonBOCQUET
Thanks ! It works !
