Get Selected Features in Custom Widget
10965
13
04-21-2021 06:00 AM
AdrianAkbariNet4s
How can I create a custom widget in experience builder that takes the current selected features from the standard selection tool?
I have read the docs and looked at the sample repos but I still cant manage to do it. Any help is appreciated jimu documentation is not really helping.
Thanks.
AlejandroMari1
Hi @AdrianAkbariNet4s , thanks for your response. Yes, that's what I'm trying to do. I will give it a try, though I don't think storing the selected features on the state will work, since that object will be updated from another widget, it won't trigger a component update on my widget.
I imagine there is a way to "listen" to selection changes in a data source, but can't figure out how. The documentation is minimal on this.
I've posted this as a separate question now: https://community.esri.com/t5/arcgis-experience-builder-questions/react-to-change-in-selection-on-da...
Thanks!
Alejandro
AdrianAkbariNet4s
I still think you can do it. In React its called " lifting your state up" . See Lifting your state up .
That is how my widget works. User selects features with the default selection tool (widget A) and the selected features gets automatically updated in my custom widget (Widget B). Or am I not understanding your question correctly?
AlejandroMari1
Thanks again @AdrianAkbariNet4s . I think you are correct. And my code is working now! Here's a snippet of my <DataSourceComponent>
    useDataSource={useDataSource}
    query={dataSource ? query : null}
    widgetId={this.props.widgetId}
    onDataSourceCreated={this.onDataSourceCreated}
    onDataSourceInfoChange={this.onDataSourceInfoChange}
    onCreateDataSourceFailed={this.onCreateDataSourceFailed}
    {this.renderChild}
</DataSourceComponent>
this.renderChild is called whenever there is a selection update on the data source, made by any other widget, including OOTB ones.
This is the only thing I'm storing in the sate when the onDataSourceInfoChange is called:
    onDataSourceInfoChange = (info: IMDataSourceInfo) => {
        this.setState({
            dataSourceStatus: info.status,
            dataSourceWidgetQueries: info.widgetQueries,
            dataSourceVersion: info.version
DougBrowning
MVP Esteemed Contributor
If there is a way to fix the Analysis widget then to see selections?  We have been trying for months and the Analysis widget cannot seem to see selections from anything.  thanks
