geosearch result question
423
10
07-31-2025 06:58 AM
dsinha
Hello,
Can anyone explain why the geosearch function (within the Search widget in Experience Builder) does not return any result or produces the message "No search results for <address>"?
Does geosearch function differently from  other map apps (e.g. Google Maps) that attempt to approximate the location based on the address range in a particular stretch of the road/block?
Thanks!
ShengdiZhang
Hi @dsinha ,
I just tested the app and everything is working fine on our end, as well as for others on the team.
I noticed in your screenshot that the request is timing out. Since it’s working normally for others, it’s likely something specific to your environment — possibly a firewall, proxy, or security setting that's blocking the request.
Other network activity might still work fine, so issues like this can be easy to overlook. If you have any security software or custom network configurations, it’s worth checking if they might be affecting this particular request. You could also try from a different network or device to help narrow it down.
ShengdiZhang
Hi @dsinha ,
I cannot reproduce this bug.
Search suggestions don’t display a "No search result" message — they simply show nothing if there are no matches. However, if you press Enter to perform the full search, the "No result" message will appear as expected.
If you're still experiencing the issue, could you please share the locator service and a sample search input so I can investigate further?
Shengdi
dsinha
Hi @ShengdiZhang ,
You are right about the wording of error message. Here is a screenshot of the sample search input and the error message.
And here is the link to the locator service:
[deleted]
Could you please confirm how the locator works when provided with an address? Does it attempt to approximate the location based on the address range on a particular stretch of the road/block or does it only return a result if the actual address exists in the real world?
Thanks for your help!
ShengdiZhang
Hi, I tried the locator service and the sample search input you provided, and the search widget works fine on my side:
Could you check the settings for the search widget? Specifically, is "only search in current map extent" checked?
dsinha
Hello @ShengdiZhang,
Did you click on the search result and see if it actually zoomed to the address location? I get the error message when I click on the search result.
Also, the locator I shared is a custom locator (Carlisle Geosearch) for our area of operation. Not sure if that is the reason I do not see the "only search in current map extent" option you referred to.
ShengdiZhang
Hi @dsinha , which version of Experience Builder are you using? This bug isn't reproducible in the latest ArcGIS Online environment, but it may still be reproducible in an Enterprise environment.
dsinha
Hello @ShengdiZhang, I am using Experience Builder in Enterprise 11.2.
Thanks!
ShengdiZhang
Hi @dsinha , "I tested this in an 11.2 environment, and everything is still working as expected on my side. Could you please check the following requests in the Developer Tools > Network tab?
From my end, they all return the correct values.
Do you see any error messages associated with these two requests on your side?
Shengdi
dsinha
Hello @ShengdiZhang
Here are the screenshots with the information you requested.
You can verify the information by visiting the app page (its a public map):
https://arcgissvr.borough.carlislepa.org/portal/apps/experiencebuilder/experience/?id=37efdb2af3b842...
ShengdiZhang
Hi @dsinha ,
