geosearch result question
2024
11
07-31-2025 06:58 AM
dsinha
Can anyone explain why the geosearch function (within the Search widget in Experience Builder) does not return any result or produces the message "No search results for <address>"?
Does geosearch function differently from  other map apps (e.g. Google Maps) that attempt to approximate the location based on the address range in a particular stretch of the road/block?
Thanks!
dsinha
Thanks @ShengdiZhang, you are absolutely right. When I tested the app outside our network, it worked fine.
I have contacted our IT team to figure out a solution.
dsinha
This turned out to be a bug in Enterprise 11.2 that has been fixed in 11.4 and 12.
BUG-000175685: The Locator View is not working correctly when configured to search within a specified area in ArcGIS Experience Builder.
