Geocode a CSV file using Analysis tool in Mapviewer does not work.
699
03-12-2026 04:33 PM
mmoka
I have a CSV file. I added this as an item in the Portal. (did not host it)
Now, I am trying to geocode the points in CSV file in a MapGeocode CSV to Featurelayer without hosting CSV in Portal.jpg using the Analysis tool. It does not work. Fields shown
ToddW_stl
Can you share the CSV?  Have you tried renaming the highlighted column to just "State"?
ToddW_stl
mmoka
Here is the CSV.
mmoka
when adding the file choose this option.
mmoka
Don't publish the item. If we publish, it will work.
