Flitering the Same Web Map throughout Multple Pages in Experience Builder
1083
08-16-2024 08:09 AM
ThomasGoodridge
I have this maintenance request dashboard in Expeerience Builder. It's split between multiple pages called 'Buildings', 'Grounds', 'Projects', and 'Scheduled Maintenance'.
They all share the same web map, and I was wondering if there was a way I could use the filter widget, or something similar, to automatically remove data that isn't relevent to the current page without creating four seperate web maps.
Right now, the filter widgets filter every page at once, which means I have to remember to turn off the filter in one page before activating it in another. This may confuse users, aby help would be greatly appreciated.
LindaStewart
Technically, it is the same web map, but you will need to add it 4 times to ExB. Each time you click on the "add new data", you can turn off the layers you dont want and it will be added to your data list as a new map. Then in your data, you can rename the map to denote what it's used for
LindaStewart
