Feature Info widget is showing all the attributes in the popup window as blank when we have a direct URL in the popup
1427
05-15-2024 10:22 AM
AndrewWallick
We're running into an issue where the Feature Info widget is showing all the attributes in the popup window as blank when we have a direct URL in the popup.
1. I've reproduced it with two separate Feature Info widgets with different layers
2. It doesn't happen when the exact same URL is put in as a hyperlink with alternate text
3. It somehow happens (attributes are blank) when the URL is put in as a hyperlink with the same URL as the text (see third screenshot below).
4. This doesn't happen in the web map popup.
5. It does not happen with the base URL for the experience builder, or with "https://www.google.com/". But it's reproducible for us when the URL for the exp builder app includes a selected feature.
6. It happens also when the URL is a different exp builder app (as long as there's a selected feature)
We have a workaround now, so I don't need to make a full support ticket. But this is a weird bug so wanted to let the team at Esri know.
Wei_Ying
@AndrewWallick Thanks for your feedback!
As I tired, it looks like UI issue, the attributes are not empty, but the long URL string makes the content display logger when the widget layout. So the attributes info are hidden and you have to manually scroll to right or resize the widget.
We will work on to fix this display issue. Thank you!
MollyWalkner_1
@AndrewWallick and @Wei_Ying thanks for posting this. I'm also running into a similar issue. When I'm including a hyper link to a survey123 survey in the feature info widget, I'm unable to access it. The feature info widget alters the link to the ExB base with url parameters from the selected feature, instead of linking to the actual URL.
If the same url is included in a hyperlink with different text in the feature's pop-up, then the link correctly goes to the survey.
Wei_Ying
Hi @MollyWalkner_1 ,
Thanks for your feedback. Would you be able to share a copy of the app for us to investigate?
