Filter Widget - Show no values when nothing is selected
1147
04-08-2025 07:16 AM
C_McNamara
Hello!
How do you show no values when you do not have a selection in a filter?
The image below shows the default of a group filter. The text element (highlighted by the green box) is returning the first value in my feature layer. I see  that the filter is actually on 'All' but i don't know if I have any other default choices.
How do I not show this first value?
Works completely fine after I select an area to filter on:
Colin
Ke_Xu
by Esri Regular Contributor
Hi @C_McNamara,
In SQL Expression Builder, please choose the first value in the dropdown. The value will be shown in the Filter.
Ke
C_McNamara
Hi @Ke_Xu,
Thanks for the reply!
I specifically don't want any value shown.
I am also using a the group sql filter and using "Unique" as the select source type:
I don't have any option for "no filter/selection" here:
Ke_Xu
Hi @C_McNamara,
Currently, only All can be displayed.
Ke
C_McNamara
Hi Ke,
I decided to use predefined unique values. That was the only way to get rid of "All".
