Filter Widget - Multiple Selection
3208
13
08-16-2022 06:45 AM
TheGamer
So, I'm trying to select multiple names however it only allows me to select 1 name. There are times when I can select them but I have to click on the boxes really fast and even when I'm able to select them. The filter does not work properly. Basically, I want the user to select a province, and based on that it should only show the user the names associated with the selected province, and from there they should be allowed to select multiple names. The filter is working for one of my views, however, when I replicate the process for other views (the layer being filtered for each view is the same), I'm only able to select it once. Could you please help @TonghuiMing @@ShengdiZhang @jcarlson
TonghuiMing
@TheGamer This issue has been fixed in the latest AGOL 10.3 release. Thanks.
K_Smyth4
Hi there, I am having a similar issue with the filter widget on an application I have built, I have added in single clauses and haven't used a clause set has had come across issues using this. I am looking to filter a dataset by Council area in Northern Ireland which has 11 Councils but each time I configure the widget and filter in the application, it only shows me 3 of the 11 Councils to chose from? Thanks
TonghuiMing
@K_Smyth4 Are you still seeing this in the AGOL environment and it is possible to share a sample app? I could not reproduce it with a clause set. Or are you in a previous Enterprise/dev edition version?
K_Smyth4
Hi there, yes I am still seeing the issue and can create a test app for sharing, the filter works perfectly in the web map and it only seems to be an issue in Experience Builder, I am using AGOL and not an Enterprise version. I've taken a look online and have found a workaround for not seeing the list but it is for sharing with a customer and keen to see if there are any simple solutions, will share the app as soon as possible
